Nikita, the Alpine `87 325is REVISED getting built for the track!
  • kingston
    • Jun 2010
    • 2669
    My name is Kingston, and I'm a BMW hoarder.*
    "Hi Kingston."
    Yesterday I picked up a lovely `87 325iS in Alpineweiss with the express purpose of taking her to the track...
    ...and then I changed my mind...I mean, she's just so CLEAN...
    ...and then I changed it back again!
    I already own an `86 325 coupe in Zinno.
    She's making the transformation into a Chump Car racer. Not what I'd initially envisioned for her, but when the Alpine iS came into the picture, things changed. (See here for the initial build for Lilo: http://www.r3vlimited.com/board/showthread.php?t=227292)
    In addition, I have Siobhan, an M50-Swapped, BBS RX-shod `88 325 sedan that's my daily driver.
    (Here's Siobhan's build thread: http://www.r3vlimited.com/board/showthread.php?t=217284)
    Here's where it gets complicated...
    The bottom line is that the body new Alpine iS in really good shape. Too good for the track. My Sedan's body is pretty rough. Rough enough that unless I spend a fortune on her, she's never going to look anywhere near as good as she goes. But I am so attached to my sedan, that I just couldn't bring myself to gut her!
    So, the plan is this:
    #1 Gut the car
    #2 Install a cage
    #3 Install all the suspension stuff for SE30
    #4 Keep racing Chump Car in Lilo in `13, and do as many HPDEs as possible. Shoot for Comp license & SE30 racing in `14!
    Today was time to chase down a few problems. Things I fixed:
    * Check panel didn't work. Easy fix, as it was just unplugged. For a reason, as it turns out, since virtually every light was illuminated!
    * Third brake light didn't work. Simple fix - just a burned out bulb. Turned that light off.
    * License plate light and rear brake light warnings were both illuminated on the check panel. Both rear lights and the license plate lights actually worked.
    * Fixed the non-working horns. Simply a matter of swapping the MTech-I steering wheel from the Zinno car into the Alpine car. For some reason, this also made the License plate and rear light warning lights on the check panel turn off. Go figure!
    Things I still need to fix:
    *The oil level light is still illuminated (and the oil is low; I'll pick some up this week UPDATE: Adding oil to the proper level turned the light off.
    * Also, the coolant level light is illuminated on the check panel. The sensor itself is broken, but I have a new one on order from Levent at Guten Parts. UPDATE: Part is installed, light is fixed. I don't know yet if I will keep the Check Panel or not, but at least this way I know wtuff is working properly!
    * The brakes suck. The pedal travels pretty darn far without actually slowing the car down. I bled the brakes today hoping for an easy fix, but it was not to be. The pads have plenty of life left in them, although they are mismatched. I've ordered a new Master Cylinder and PBR front pads. UPDATE: New master cylinder didn't help much, nor did rebuilding the front calipers. MY ABS light is illuminated. I tried using a pressure bleeder, but I think I need to go back to the old-school 2-person method...
    * Wiper moter est kaput. Can't wait to change that. Should be fun. Har-dee-har Update: I recommend leaving this job to someone else. Someone you don't like. It SUCKS. Also, make sure you know exactly what position your windshield wiper transmission is in, because re-clocking the wipers also sucks.
    PS, here's my tribe:
    Last edited by kingston; 04-30-2013, 06:06 AM. Reason: * Courtesy of Doug Hitchcock :)
    Originally posted by LJ851
    kingston is the play by play announcer for this thread.
    ‘Tis by the grace of God that my cars run!
    Originally posted by unloadedak
    #teamross
    Siobhan's Build Thread - UPDATED!
  • red_e30
    • Dec 2010
    • 242
    nice man looks like some good plans sub'd to see results
    my build thread:http://www.r3vlimited.com/board/showthread.php?t=232324
    • kingston
      • Jun 2010
      • 2669
      It's been long enough ago that I started this thread that I'd forgotten all about it! Some updates:
      The brakes sucked. I picked up a new Master Cylinder, Textar pads and ATE caliper rebuild kits for the front from Levent at Guten Parts. My friends Mike and Jeremy provided me with Brembo rotors and SS brake lines, respectively.
      La Femme Nikita on jack-stands, mid-surgery
      Next up was installing a set of Recaro Pole Positions. These are out of the FIA approval date, so I'll have to run a seat back brace when the time comes to actually race her.
      The passenger side is not faded, that's just the flash from my DROID phone's camera...
      This is the engine that I was originally going to put in Nikita. Instead, she'll now replace the M50 in Siobhan, my DD. I took the head off of the S52 and gave it to my friend Tim England (Philo on R3V). Tim's having a very good BMW shop (one that rhymes with Shmetric Shmechanic) breathe on the head as a side-project.
      Two of the valves were leaking, so that will be addressed along with new guides & seats, and we're decking the head for a little more compression...
      The bottom end is in GREAT shape! Cylinder walls are absolutely perfect.
      I'll clean up the block next weekend and get it prepped and painted.
      Can't wait to do more!
      #teamross
      • XW70
        • 290
        nice collection of e30s, jealous indeed
        Delphin '87 325i Vert
        • Joe G
          • 2947
          Noice!
          Current Car: 2011 BMW 135i, M-Sport, 6 speed
          Originally posted by lambo
          Sounds like you need a massage.
          Originally posted by kpeng
          Who the hell is Vlad?
          • kingston
            • Jun 2010
            • 2669
            Aaaaaaand I just put down a deposit on an awesome set of wheels! Details soon!
            UPDATE: The wheels, 3-piece CSIs in 4x100 (incredibly rare!), will go on Siobhan. I have picked up a set of SE30-legal TRMs in 15x7, ET25.
            #teamross
            • M42Technik
              • 9781
              Watching this thread :)
              Reminiscing...
              • kingston
                • Jun 2010
                • 2669
                Hah! That's funny! Can't wait until the 19th, so I can officially announce the wheels :)
                I am also picking up an M52 for my wife's 318ti...`cause I don't have enough projects. BWAAAHAHAHAHAH!...
                #teamross
                • JCarp90
                  • Feb 2011
                  • 1759
                  Mmm. I'm sexy.
                  • M42Technik
                    • 9781
                    You should be getting another package in the mail today! :)
                    Reminiscing...
                    • kingston
                      • Jun 2010
                      • 2669
                      Oh, I KNOW! I've been up since 3 in the morning! Couldn't sleep `cause I'm so excited!!!!
                      #teamross
                      • Joe G
                        • 2947
                        Kingston. I mis-spoke, this weekend I am free. Next weekend is the concert. Hit me up in Facebook if you want to do some wrenching.
                        • kingston
                          • Jun 2010
                          • 2669
                          I may just do that. I have a busy weekend o' wrenching planned already, and I just broke a rear half-shaft. Poop.
                          Still, plenty of other stuff to do!! Shoot me a PM with your # (I don't think I already have it).
                          Cheers!
                          #teamross
                          • M42Technik
                            • 9781
                            Mar 23, 2012 6:28 AM: On FedEx vehicle for delivery, KANSAS CITY, MO
                            Reminiscing...
                            • kingston
                              • Jun 2010
                              • 2669
                              They're here!!!!!!!!
                              VERY rare 3-piece CSI wheels. 15x7, et22. 4x100
                              I cannot say enough good things about how Daniel (M42Technik) was to work with for this transaction! I know he has a set of MHW tails for sale, and I would not hesitate to buy from him. Plus, he's a cool guy, with great taste in all things E30!
                              I'll be cleaning these up a bit, and painting the centers either light grey or a dark silver. Can't WAIT!!!!!
                              #teamross
